1st March February 2012
Latest post 06-23-2008 4:05 PM by GuyHui . 10 replies.
06-22-2008 11:00 PM
Beolab
- Joined on 05-18-2007
- Sweden
- Posts 535
I need a picture of an all black BeoLab 10
I need pictures of an all black BeoLab 10.
Regards
Stars
- Joined on 04-24-2007
- London
- Posts 1,483
Re: I need a picture of an all black BeoLab 10
My dealer said the all black BeoLab 10 won't be out until the end of summer. I'm sure you probably already know, but the all black BeoLab 10 is only a minor difference to the aluminium model. The thin metal edge round the speaker is black instead of the brushed aluminium. The ALT will still be aluminium as we have been used to see it.
Tom
- Joined on 04-16-2007
- Luxembourg
- Posts 3,175
Hi Beolab! I guess you would like to add the BL10 to one of your BV7-40?! I have been told here on the forum, that the BL10 will only fit the BV4 and not the BV7. Can you confirm this?
Music washes away from the soul the dust of everyday life. - Berthold Auerbach
Beolab
- Sweden
- Posts 535
Tom: Hi Beolab! I guess you would like to add the BL10 to one of your BV7-40?! I have been told here on the forum, that the BL10 will only fit the BV4 and not the BV7. Can you confirm this?
Hi Tom! The answear to this is: STB brackets! =) If you got a BL 7-4 you can order this new black anodised adapter 10MS40 is designed for use with Vertical Floor Stand 4041. 10MS40 fixes to the standard BeoLab 7.4 speaker hanger (3151916). http://www.stbbrackets.co.uk/?page=proddetail&catID=5&ProdID=1074
I have orderd the BLab 10MS40 bracket now im about to order the black frame to the BV7 and a all Black BL10= The new AV7-40 =) Regards
Beolab
- Sweden
- Posts 535
Hi Tom! The answer to this is: STB brackets! =) If you got a BL 7-4 you can order this new black anodized adapter 10MS40 is designed for use with Vertical Floor Stand 4041. 10MS40 fixes to the standard BeoLab 7.4 speaker hanger (3151916). http://www.stbbrackets.co.uk/?page=proddetail&catID=5&ProdID=1074
I have ordered the BLab 10MS40 bracket now and about to order the black frame to my BV7 and an all Black BL10= The new AV7-40  Regards
beojeff
- Joined on 11-29-2007
- Posts 543
I have a Beolab 10 with the silver trim. The trim is actually on the removable speaker grill. Therefore, it will be very easy to change this in the future. The front grill attaches with large pegs similar to those of the newer, metallic beolab 2500 grills. This will make is so much easier to change than the frets on a beolab 6000.
GuyHui
- Joined on 03-17-2007
- Posts 1,560
I like the BL10's implementation on the BV7 40. It has something of the AV9000. Very nice setup you have BTW, BL5's are incredible.
Guy
--= "Everything gets done with Patience" =--
--= "Less is More" - Mies Van der Rohe"
--= BV10 46", BL8K, BL4K, BL2, BS Ouverture, BC6000 (Mk3), BT1100, Beo4 , A8 and ...the Atomic Floyd "Airjax+Mic" earphones =--
Tom
- Luxembourg
- Posts 3,175
I could have guessed that. But I'm not sure if I like that look...
moxxey
- Joined on 04-14-2007
- South West, UK
- Posts 2,360
BeoLab, maybe I heard incorrect information, but I was told by a guy from B&O UK that they weren't happy with this BL10 -> BV7 bracket and they may even consider not supporting the warranty on the BL10 if it's installed on a BV7! Strong information, but that didn't come from a dealer, that came from B&O UK. He did say that they were only 'considering' their position, but weren't happy at all.
Daniel
- Joined on 04-17-2007
- Svinarp, Sweden
- Posts 1,284
GuyHui : Very nice setup you have BTW, BL5's are incredible.
The photo is not Beolabs setup. It's a photo from STB. Beolab has black 8000´s as stated in his signature.
GuyHui
- Posts 1,560
You are right. Guy
Page 1 of 1 (11 items)
