Latest post 06-15-2008 9:49 AM by psc. 4 replies.
Page 1 of 1 (5 items)
  • 06-14-2008 8:24 PM
    • psc
    • Not Ranked
    • Joined on 06-15-2008
    • Posts 3
    Beosystem 2 it's not full HD?
    Hi everyone,
    Need some advice on this subject please: I'm acquiring a used Beovision 4-50'' + Beosystem 2. The problem is that some of my friends are telling me that the beosystem 2 is not full HD, but is only HD ready (even in the retailer they could not explain this accurately).
    the beosystem 3 being the 'full HD' real and only option(...)
    Could someone help me interpreting this differences here?
    Thanks in advance
    pedro
  • 06-15-2008 5:44 AM In reply to
    • StUrrock
    • Top 500 Contributor
    • Joined on 02-04-2008
    • Cambridgeshire
    • Posts 219
    Re: Beosystem 2 it's not full HD?
    As the BS2 does not have any HD connections on it it is purely acting as a switching box so it is the resolution of the screen that is the important question. If the BS2 has the hd software it will tell the screen to receive the input from the DVI socket not the VGA when a HD source is selected.
    Hope this helps.
  • 06-15-2008 6:34 AM In reply to
    • psc
    • Not Ranked
    • Posts 3
    Ok I see. Many thanks.
    So I assume there's some BS2 units with HD software, is that it, or should I assume this only happens with BS3?
  • 06-15-2008 7:29 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Technically the BS2 or 1 will never actually handle HD, it will just pass the signal straight through to the panel - which means you don't get any of the B&O picture processing. A BeoSystem 3 will provide a far superior image!
     Weekly top artists:
  • 06-15-2008 9:49 AM In reply to
    • psc
    • Not Ranked
    • Posts 3
    Ok, now I've got it. Thanks
    Cheers, Pedro
