Santiago:
Toubro:
TripEnglish:I tried pressing stop for a while and it doesn't work on any of the current gear. That would be quite an easter egg if it were true!
It works on my Avant DVD32RF, and opens the dvd player.
Exactly the same here!
it opens the dvd player cover of my avantDVD even when a disc is playing
Is this manipulation still works with something else than the Avant DVD series, I mean with any Beosounds ?
I seems it just doesn't do the thing when pressing the stop button for a while. I am attempting to eject the CD of my BS Ouverture. But the CD clamper does not move at all.
Thanks for your feedback.
Guy
--= "Everything gets done with Patience" =--
--= "Less is More" - Mies Van der Rohe"
--= BV10 46", BL8K, BL4K, BL2, BS Ouverture, BC6000 (Mk3), BT1100, Beo4 , A8 and ...the Atomic Floyd "Airjax+Mic" earphones =--
