Latest post 06-12-2008 8:38 PM by drevil2k2. 2 replies.
Page 1 of 1 (3 items)
  • 06-12-2008 2:33 PM
    Audio/aux link pin outs
    Hi all
    I need a datalink/audio aux link cable quickly, and the only one I have has had one end chopped off.
    I am happy enough putting a new end on, and have found a diagram on beotech detailing the pin outs, but I don't know which colour cables relate to each function.
    Can anyone help?
  • 06-12-2008 4:20 PM In reply to
    Re: Audio/aux link pin outs
    I don't think you should decide anything on the colours, they could be connected just about any fri*ing way depending on what mood the manufacturer was on. Measure them, or if you can slide the sleeve off the remaining connector, look inside it.
    When I needed one, I could have made it up myself, but just decided to save myself the trouble of soldering and hunting for suitable raw cable, and bought one off eBay:
    http://stores.ebay.de/AV-Solutions-Store_Cables_W0QQcolZ4QQdirZ1QQfsubZ2626337QQftidZ2QQtZkm
    Arrived quickly, and the quality is just fine.
    -mika
  • 06-12-2008 8:38 PM In reply to
    Over in North America, I ordered from this guy
    http://myworld.ebay.ca/lazerwave/
    and the data cable seems to be ok.
