1st March February 2012
06-07-2008 6:07 PM
Ryan
- Joined on 04-16-2007
- Toronto
- Posts 29
Automatic Colour Management added to BV9
http://www.engadgethd.com/2008/06/06/bang-and-olufsens-beovision-9-now-graced-with-automatic-color-ma/ "We are very eager to extend our Automatic Colour Management technology to our flagship plasma and renowned home entertainment solution, BeoVision 9", states Zean Nielsen, President of Bang & Olufsen America, Inc. "With its digital surround sound capabilities, integrated loudspeaker featuring an acoustic lens, full high definition picture quality, and now Automatic Colour Management, we believe BeoVision 9 will set a new standard in home theater offerings and provide our customers the quintessential sound and picture experience." Automatic Colour Management adjusts the color temperature of the plasma screen to compensate for the effects of phosphor aging, which over time, causes a shift in the white level -- resulting in an increasingly yellow picture. Upon activation, a short robotic arm swings down from the upper part of the frame. A miniature camera is located at the end of the arm, which analyzes a test picture on the screen. The color temperature in the white and black areas is measured and then adjusted to ensure correct color balance, even after thousands of hours of use. Automatic Colour Management is routinely activated after every 120 hours of use, but can also be activated manually. Additionally, BeoVision 9, adjusts brightness, color and contrast picture settings according to its placement and the lighting conditions in the room. Through an optical sensor on the top of the frame, BeoVision 9 measures ambient room lighting then automatically dims or brightens itself to deliver the optimal viewing experience for those conditions.
BeoVision 9 with Automatic Colour Management will be available in July 2008 in silver frame/silver speaker cover and silver frame/black speaker cover combinations. Additional color options for the frame include red, blue, black and dark grey and will be available late summer 2008
mr_anders_son
- Joined on 03-27-2007
- sweden
- Posts 1,032
Re: Automatic Colour Management added to BV9
Ryan: http://www.engadgethd.com/2008/06/06/bang-and-olufsens-beovision-9-now-graced-with-automatic-color-ma/ "We are very eager to extend our Automatic Colour Management technology to our flagship plasma and renowned home entertainment solution, BeoVision 9", states Zean Nielsen, President of Bang & Olufsen America, Inc. "With its digital surround sound capabilities, integrated loudspeaker featuring an acoustic lens, full high definition picture quality, and now Automatic Colour Management, we believe BeoVision 9 will set a new standard in home theater offerings and provide our customers the quintessential sound and picture experience." Automatic Colour Management adjusts the color temperature of the plasma screen to compensate for the effects of phosphor aging, which over time, causes a shift in the white level -- resulting in an increasingly yellow picture. Upon activation, a short robotic arm swings down from the upper part of the frame. A miniature camera is located at the end of the arm, which analyzes a test picture on the screen. The color temperature in the white and black areas is measured and then adjusted to ensure correct color balance, even after thousands of hours of use. Automatic Colour Management is routinely activated after every 120 hours of use, but can also be activated manually. Additionally, BeoVision 9, adjusts brightness, color and contrast picture settings according to its placement and the lighting conditions in the room. Through an optical sensor on the top of the frame, BeoVision 9 measures ambient room lighting then automatically dims or brightens itself to deliver the optimal viewing experience for those conditions.
or here  http://forum.beoworld.org/forums/thread/119889.aspx
mr_anders_son
- sweden
- Posts 1,032
Page 1 of 1 (3 items)
