Latest post 06-05-2008 8:13 AM by Russ. 3 replies.
Page 1 of 1 (4 items)
  • 06-04-2008 1:42 AM
    • rex
    • Not Ranked
    • Joined on 06-03-2008
    • Posts 4
    Beo 7.1 Active Loud Speaker Troubleshoot
    I have an non-bang and olufsen amplifier with pre-amp abilities. But i cant get my B&O speaker to output sound. Or alternatively connect the speaker to my iMac computer via an airport express. Has anyone managed to do this?
    Arthur
  • 06-04-2008 11:31 AM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Re: Beo 7.1 Active Loud Speaker Troubleshoot
    Most likely you are simply missing one piece of kit.  Like the BeoLab 2, the BeoLab 7-X speakers were intended strictly for use with a B&O master with PowerLink outputs.  As such, there is no 'Line in' setting on the speaker, which means the internal amplifier never switches on (the trigger is in cluded in the PL cable).
    Here in the US B&O sell an adaptor (898127) whch will supply RCA to DIN connection, and the trigger voltage to turn the speaker on.  Note that unless the power supply is attached to a switched outlet the speaker is always powered up.
    Russ
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 06-04-2008 11:16 PM In reply to
    • rex
    • Not Ranked
    • Posts 4
    Thanks Russ for that info. I rang around for that cable you told me about ,but here in Australia b&o haven't heard of it .I was wondering if you could tell me where to purchase  one from.....
    regards REX
  • 06-05-2008 8:13 AM In reply to
    • Russ
    • Posts 641
    Rex,
    ring 'em up again, and ask if they have a method for using a BeoLab 2 with a non-B&O receiver. The part number I gave you is one created by B&O America, so it is not an 'official' B&O/DK part.
    Russ
    McLean, VA USA
