A friend of mine has a problem with his MX5500 : he attached a multimedia hard-drive via a Peritel, but the picture goes to black & white after a nanosecond in color... (The multimedia HD works perfectly well with another non B&O TV...)
I suggested him, by phone, to switch Peritels, to set the video format to PAL and NTSC on his HD, but it doesn't work. He has a DVD player on one of the two Peritel sockets and the welcome page appears in B&W too, though it switches to color after a few seconds...
Do you guys have any clue about this issue?
BTW, following the user manual, I asked him to try "TV" + "SHIFT" + "TEXT" to access the TV set-up menu, but it only activates Teletext...
Thanks for your input,
Philippe
