Latest post 05-20-2008 8:55 AM by beoperson. 3 replies.
Page 1 of 1 (4 items)
  • 05-15-2008 2:05 PM
    BeoLab 8000 bases are not tight
    My Lab 8000 base screw became slightly loose after move to new house.
    I have tried to tightening it but no success, any recommendations? Is there a special tool required?
    Regards,
    David the BeoPerson
  • 05-15-2008 2:17 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: BeoLab 8000 bases are not tight
    The bolt under the base? Is the washer missing?
     Weekly top artists:
  • 05-15-2008 2:19 PM In reply to
    Yes, large bolt under the base.
    I don't think it's missing but will check once I get home.
    David the BeoPerson
  • 05-20-2008 8:55 AM In reply to
    It has large washer under the bolt. I tightened it - looks like it's holding it well.
    David the BeoPerson
