1st March February 2012
Latest post 05-07-2008 1:22 AM by Christian. 4 replies.
04-27-2008 6:26 PM
Christian
- Joined on 04-16-2007
- Copenhagen, Denmark
- Posts 626
Hiss from BM4500 - what might be the problem?
Hi  My parents complains about a hiss from their Beomaster 4500. Their complete setup is the following: Beomaster, Beogram, Beogram CD 4500 connected to BeoLab 8000 (Main speakers) and Beovox CX100, RedLines through MCL. The hiss or buzz comes in various intervals and last under a second. It can be head from all the speakers, so I suspect the Beomaster to have some sort of short circuit. Do any of you have a possible explanation, or better a possible solution? Best regards Christian (on behalf of my dad...)
Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
Addicted? Oh no.... ;)
BeoSideOfLife
- Joined on 04-22-2008
- Posts 24
Re: Hiss from BM4500 - what might be the problem?
Does this occur when eg changing volume? Then it could be the powerlink cables that arent sheilded enough. Data transfer can disturb audio signal.
Christian
- Posts 626
It occurs randomly, and it is not related to changing volume, radio station etc. (Sorry for answering so late...) Do anyone have a clue to what might be causing the buzz/hiss?
patrahul
- Joined on 05-04-2008
- Posts 6
It seems to me like a leaky capacitor mostly in the volume changing/switching circuitry. If the system is quite old then I would try resoldering all the joints in the above mentioned board first just to get rid of the chances of any dry solder issues. Hope this helps. Cheers, Rahul
Christian
- Posts 626
I will try to have a look at the service manual then, and see if I can locate the volume circuitry. Thanks!
Page 1 of 1 (5 items)
