Why? To replace all three units in each speaker will be far more than the speakers are worth. It would be cheaper to buy another set and if you are attached to the cabinets, swap the units. I would take the opportunity to upgrade. B&O passive speakers are cheap and some are true bargains!
The S55 is a nice speaker but the S80 and S120 are a fair bit better. And not a huge amount bigger.
