Hello
In Norway we are loosing the analoge TV broadcast now. This means we will have to have some kind of digital decoder to watch tv. But some of the point with B&O's link system for me has been that I can watch champions leage on one channel and my wife something else on another channel. Now you will need two decoders to solve that.
From a link room you can control 2 different stb if your main TV is a BV7-40. Does this mean that you cannot add for instance a Pioneer Bluray player, and control this from a link room?
Thats a pity.
This means that I have to wait till we get a BV7-40 with integrated BR player.
And what if you want a HDD recorder. You must buy B&O original, even if it might not be the best available. Otherwise you cannot control it from your link room?
There is decoders available with built in hdd, but from what I understand, you cant control the hdd from a link room...
Right now, I have an Avant which only can control one stb... I must do something...
I can't be the only one with this problem. How do you solve this??
BV10, Avant DVD, BL5, BL4000, BS2300, BV6-26, MX 4002, 2xBeocom 6000, LC2
