Hi. I have a question to ask you wizards.
Background detail: My old akai amplifier died, to which my Beogram 3300 phonograph (record player) was connected. I had the phonograph (record player that is) tested and repaired for a minor fault. Now I have a brand new Pioneer 516 Amplifier and I would like to reconnect my Beogram 3300 record player (phonograph) back up to this new AMPLIFIER.
I have reconnected the speakers (yep they work) and have an earth wire from the phonograph (record player) to the new Pioneer AMP. Not quite sure where to connect this to, so I have made a connection into one of the surround sound speaker options with this copper earth wire. The phonograph (record player) is connected in to the AMP as a "CD" and the signal input has been selected on the AMP.
The problem I need help with is this: I have no sound from the phonograph (record player) when it is on and turning! Yep the radio and other inputs all work fine (I have sound from the speakers). When I have "CD" selected on the AMP Iand if I crank the volume up on the speakers I can very faintly hear the record playing,.
Can someone please help me before I go mad!
many thanks Scullykarma.
