Latest post 06-11-2008 12:12 PM by TWG. 4 replies.
Page 1 of 1 (5 items)
  • 06-11-2008 8:22 AM
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    Beoport + Beosund 3000 (SW 1.2): Useless or possible?
    I've just ordered a Beoport and want to use it with my Beosound 3000 (SW 1.2). I read through the forums that my BS3000 needs a SW-Version higher that 2.1.
     Is my old BS3000 useless to operate with Beoport? Will nothing work when my Beoport arrives?
    Can I make a Softwareupgrade of my BS3000 from my dealer? How long does this take and how much does it cost.
    Thank you for your help.
  • 06-11-2008 8:35 AM In reply to
    • kallasr
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: Beoport + Beosund 3000 (SW 1.2): Useless or possible?
    That's exactly what I get done by a dealer right now.
    Pricing is appr. 100 Euro (even though another dealer asked for 153,15 Euro). We will see.
    I suppose it is just fitting an EEPROM...
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 06-11-2008 8:58 AM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    Hello Ralf,
    thank you for your answer. Do you know how long it takes? Do they have to send it in or do they change the Eprom in the store?
  • 06-11-2008 9:15 AM In reply to
    • kallasr
    • Posts 1,077
    Since my system is in the store right now I don't know yet, but they said it takes appr. 10 days, they do it in the store.
    You are welcome.
    Ralf
  • 06-11-2008 12:12 PM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    10 days? Oha ... that's a looooong time without my system.
     btw: Do you know what the optional IR-Eye costs?
    Thanks again for your help :)
