Latest post 05-01-2008 12:15 PM by joeyboygolf. 1 replies.
Page 1 of 1 (2 items)
  • 05-01-2008 6:49 AM
    Beosound 9000 MONO Beolab 8000
    Hello,
    I moved my system and now im having so much trouble with it since i reconnected everything abd could do with some help.
    When i plug back in the speakers 1 by one i get the left one in and it works okay but as soon as i plug in the right one the left goes off, if i have the setting on the speakers both set to right then both speakers work but its just in mono and when i use the balance control i go to the left and nothing.
    Can anyone shed any light on this for me?
    Benwilly.
  • 05-01-2008 12:15 PM In reply to
    Re: Beosound 9000 MONO Beolab 8000
    I suspect that one of your powerlink cables is broken. I have had these symptoms and one cable proved to be faulty.
    Regards Graham
