I'm trying to set up a new channel on my V8000 VCR but cannot get to the correct menu. When I select VTAPE Menu > SETUP > TUNING I get no menu, but instead am returned to the broadcast TV picture. It's very frustrating. Very occasionally (1 in 10 attempts or so) I get a glimpse of the tuning menu, but only for a split second before the TV picture takes over the screen.
I would like to define a new channel on the VCR only so I can configure it to use the decoder port of the V8000 (and hopefully get a Playstation 2 signal).
All other channels are correctly copied across from my Beovision MX7000 (connected via AV1). Alas I seem not to be able to define a new channel on the VCR alone.
Any suggestions?
