Latest post 11-02-2008 8:11 AM by Good Hifi. 6 replies.
Page 1 of 1 (7 items)
  • 10-23-2008 8:44 AM
    • dko7113
    • Top 500 Contributor
    • Joined on 09-04-2008
    • Copenhagen, Denmark
    • Posts 104
    • Gold Member
    Foam rot...
    ...why does it appear?
    Are there any possible ways to prevent it happening?
    If it is some sort of dry out, can you lubricant the foam with something?
    Regards,
    Erik
    My Beo: BeoCom 6000, BeoCom 2500, BeoCom 1401, BeoLine, BeoVision LX6000, BeoVision LX2500, BeoVision MS6000, BeoVision MX4002, BeoVision MX1500, DVD1, BeoSound 3200, BeoSound 1, BeoLab 4000, BeoGram 4500, BeoPort, BeoPlayer, 3x Beo 4, 2x BeoLink 1000, V Terminal, Form 2, Light Control 2, BeoTime
  • 10-23-2008 9:29 AM In reply to
    Re: Foam rot...
    this thread talks about it, though explanations are provided -there seems to be no complete consensus (uv, humidity, tobacco, time, quality)
    • B&o bottle opener
  • 10-23-2008 5:36 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Foam rot...
    Don't know why, but there seems to be two different ways they end up. Some just turn to a powder/dust.others seem to go sticky and wet.
    CraigSmile
  • 10-24-2008 10:47 AM In reply to
    Re: Foam rot...
    Following Buranteks thread....
    What I can share with you all is my parents still have the S45 beovox (yes the early 1980's range...) and they have been kept in a smoke free and dry environment, and were never exposed to direct sunlight..In fact they are still in the same house and position in their living room as the day they were purchased..... they are in mint condition 25 years on and with no sign of dreaded foam rot... in fact, frankly I still think that they sound very good ... used on a daily basis as they are.
    If we were to take these as a sort of control, then we could perhaps conclude that environmental conditions do make the foam degrade faster, I would imagine as some have surmised the UV in sunlight and also smoke chemicals would speed up the chemical reaction that causes the rot in the foam. That would be why in some cases they seem to 'dry out' and some appear to 'melt' depending on their exposure. Think how styrofoam melts when exposed to certain chemicals. I would think this is more the case than a random production defect..
  • 10-24-2008 2:20 PM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Foam rot...
    I think S45's have rubber surrounds though as that would explain this.
    I have yet to come across any S type speakers with original foam surround which haven't suffered from rot.
    Chris.
  • 10-24-2008 10:50 PM In reply to
    Re: Foam rot...
    Hi Chris,
    Unfortunately, they are not what is considered the 'better' 3 way S45-2 of the late 70s, they are the revised 2 way uniphase range from 1983 onwards... just checked online for the type no. its  6427. So I believe they definitely have the foam woofer on them....
    Just thought you'd all like to hear of one set of this generation that has survived with absolutely no work on them at all! Altho given my success with recapping might treat my parents to this soon too...
  • 11-02-2008 8:11 AM In reply to
    Re: Foam rot...
    There's no way to prevent foam rot, hoever, you van slow the process down:
    • keep your speakers away from direct sunlight
    • keep your speakers away from heaters
    • keep your speakers in a smoke free environment
    After some time, all foam rings will deteriorate. Replacement is the only option, besides buying new speakers.
    Good Hifi
