1st March February 2012
Latest post 04-20-2008 3:20 PM by thorne. 15 replies.
04-15-2008 9:47 AM
timhanna
- Joined on 11-28-2007
- London
- Posts 602
Set Top Boxes (STB) Europe-Wide?
Hi, My company wants to send me to live and work in Paris, therefore my Virgin Media STB will not come with me. However, I was wondering if I bought a HUMAX freeview box for example, would it work both in the France, and the UK whenever I'm supposed to return? Would it work in other parts of europe, or are they supposed to just work in the country they are purchased from? I know france, in my case use SECAM, most of europe is PAL... would this be an issue for a digibox? Thank you!
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
Re: Set Top Boxes (STB) Europe-Wide?
The fact that France uses SECAM is not an issue to you because you are using a STB and you would use the RGB output from it via the SCART connector. The Humax freeview box should pick up the free MPEG2 channels, but they don't use MHEG so digital text and interactive channels won't work. France has its own version of Freeview called TNT-gratuite - http://www.tnt-gratuite.fr, it should pick up some of these French channels. What is MHEG MHEG is an acronym for the "Multimedia and Hypermedia information coding Expert Group" (MHEG). It was developed in the mid 1990s as part of the DAVIC (Digital Audio Video Council) standardisation effort to support interactivity and navigation of multimedia services. It was first implemented by ONdigital in the UK which subsequently became Freeview.
timhanna
- London
- Posts 602
Hi Keith, thanks again. did you have a good celebration? So its better that I just wait and get one in France i presume? Tim
Keith Saunders
- Posts 3,810
I had a good day, thank you Tim. Given the quite low price of STB's I would get a french unit. All french STB's also output in PAL and RGB
timhanna
- London
- Posts 602
Perfect. I am happy to hear that you had fun, Ill go for the French ones, should my STB-C software be ok? Or will i need a fresh French datatable?
Keith Saunders
- Posts 3,810
The STB controller table includes STB's from many countries. Do you know what STB table version you have ? Either look on the back of the Beovision for a very small blue label with black writing or you can go into the Service menu and it will state it.
timhanna
- London
- Posts 602
i think its SW3.0? or 3.1?
Keith Saunders
- Posts 3,810
You have a software version and a table version, its the table version which is important. You can download a list for Table Version 3.0 HERE The latest table versions are 3.90 & 3.91
thorne
- Joined on 05-12-2007
- Posts 100
Does this mean I can simply install a freeview box in France and receive the Freeview channels I would receive in the UK? If this is true, this is great news for me, because I have just bought a flat in France which does not allow satellite dishes but only a communal arial
thorne
- Posts 100
Thanks Keith. So only French channels, then. Not a stimulating prospect! Is there anything I can do to receive English channels in France, given the restrictions I have already mentioned?
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
thorne: Thanks Keith. So only French channels, then. Not a stimulating prospect! Is there anything I can do to receive English channels in France, given the restrictions I have already mentioned?
Get Sky!!! You must have a UK address to subscribe though. (a relative perhaps)
thorne
- Posts 100
Thanks again. Yes, we do have south and sout east windows, but again the problem is we are not allowed to install a satellite or indeed any other aerials apart from the communal one
Keith Saunders
- Posts 3,810
As you have South/South East facing windows you could purchase a portable unit like the one HERE and place it just inside the window on the floor. You will then be able to pick up all the BBC & ITV free to air channels
thorne
- Posts 100
Thanks a million. Cant wait to give it a try
Page 1 of 1 (16 items)
