This transformer has a thermal fuse,sometimes you can remove the fuse and wire a new one in.Otherwise you have to replace the transformer.If it looks "cooked",I suspect a problem with the secondary stage,it's a switch mode chip circuit!
I have the manual,and could copy the relevant section.
Regards,
Nick
