Hi all,
I have bought a second Beolink 7000 for a fairly good price but i have big problems with it. I have taken away all componets in the Panel-settings and then re-added them and still get the "no contact" message. It works in 1-way and with one of my LC1. Is this the classic fault of bad condensators? The prior owner used it with a AV9000 (i think) and it has typenr 1540 but a much newer version then my old, this one have s/w 2.2S, the SN-stickers on the controller itself is "gone" but the info are on the table-charger.
Another bad thing is that it never "sleeps". If you dont touch it for 30 sec i goes black but then just seconds after it goes "alive" again. I know that the old owner have himself changed the batterypack, its not a B&O-work, could there be something with that?
Helpful for all the tips, i think im fairly sure that its not a settingserror since i have my "old" Beolink up and running with no problems and i have hidden the beolinks well prior to use.
Cheers
 Jesper L
Sweden
