Resolved to some degree.
The PC command was used on the BV7 a while ago. I used the L-PC command to remove the link command. It then runs locally though the active.
BTW: If the PC Input does not detect an audio signal it still send the command down ML. Is there further technical information on this PC input connection?
Beoaus.
