Latest post 04-11-2008 10:36 PM by jk1002. 5 replies.
Page 1 of 1 (6 items)
  • 04-09-2008 6:49 AM
    IPod Integration to BC2
    Hi
    Through this forum I have found a reference to http://home.swipnet.se/ridax/ipod.htm as a means to integrate an iPod with B&O BC2 system.The recommended solution is using the Apple Universal dock with an IR Cable, all assembled and supplied as one.
    Does anybody have any comments about this? Does it work? Is it reasonably 'robust'? I am assuming the level of (B&O Remote) control suggested by the web site.
    Thanks,
    Clive
  • 04-09-2008 8:18 AM In reply to
    Re: IPod Integration to BC2
    Ridax is a member of the forum - though not here that much. I have heard only good reports of the device.
  • 04-09-2008 9:07 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Hi Clive,
    I highly recommend the ridax ipod-station. It works really great. I have mine since about 2 years now, it is the datalink-version, connected to  BS 7000 A.TAPE 2 socket,, so I can control it via N.MUSIC on Beo4. This works also from linkrooms. And it also works connected to my BC 9500 and my MCL 2AV. For newer audiosystems like BS 9000, 3000... you will need the IR version, because these systems have no datalink pin on the AUX-sockets, which means, you can`t control your ipod from linkrooms. If you plug your ipod into the station,your ipod,  the audiomaster and speakers will be switched on, and music starts playing - very nice (datalink version, I`m not sure about IR version...). Pressing STDBY will switch your audiomaster, speakers and ipod off.
    BTW Mikael (ridax) is a very friendly and helpful guy.
    Hope this helps
    Stefan
  • 04-11-2008 11:17 AM In reply to
    Hi
    Thanks to you both for the positive feedback - it is appreciated.
    Clive
  • 04-11-2008 12:04 PM In reply to
    • Alex
    • Top 25 Contributor
    • Bath & Cardiff, UK
    • Posts 2,990
    I'm interested in seeing if I can get Ridax's system to work with an Apple TV, I'm sure it's not too difficult...
     Weekly top artists:
  • 04-11-2008 10:36 PM In reply to
    He works via the Dock Connector so A TV is a no. I remember that he mentioned that this was quite a bit of work to get the Beo 4 compatible IR  into the Ipod dock.
    Since my BV8 can control the ATV sooner or later other TVs should be able too. And then there is also the kit from Oneremote that enhancers the Beo4.
    JK
