Latest post 04-04-2008 2:49 PM by Frank Rizzo. 3 replies.
Page 1 of 1 (4 items)
  • 04-04-2008 12:59 AM
    AV 7000 with outboard passive equalizer...
    Hi guys..
    You helped me with this before...on another unit (BC 9500)....now....here's what i'm wanting to know...
     Got an AV 7000 connected to Aux/Datalink to a 1611 converter.....to ML ....to the BS 9000.....
    Connecting all 5 speakers to the AV 7000 as it says in the manual.....
    Question:  Is there any way to connect a passive equalizer to this set up??
    If so....where....i don't see connections on the AV 7000 that would work...would this go into the BS9000???
    If so...how would this work...as all the speakers are connected to the AV 7000....
    THanks...keith
  • 04-04-2008 11:40 AM In reply to
    Re: AV 7000 with outboard passive equalizer...
    any ideas:??
  • 04-04-2008 1:40 PM In reply to
    • PL212
    • Top 200 Contributor
    • Joined on 02-14-2007
    • Moderator - Seattle
    • Posts 318
    The short answer is no, there is no way to do this. The difference between the passive center and the active front and rears make this untenable. You can always adjust Bass and Treble within the AV7000 itself, however
  • 04-04-2008 2:49 PM In reply to
    Thanks.....much appreciated !!
