I have had a pair of BeoLab 4000s for about 8 or 9 years now.
They are fed from a Technics amplifier via B&O attenuators, so they are activated by the audio input.
One has always been quicker to shut down than the other, but it now seems to power off during quiet passages of music.
Is the threshold/delay tweakable internally? is there a component failure that could cause this? is it possible to disable the auto feature completely? (I'd be quite happy to switch them on and off manually)
Any suggestions gratefully received.
Peter
