I'm planning to buy a used Beocord V8000 to replace my V6000. Is there anything i should be aware of (sw version etc.)?
Best regardsRasmus
Avant CTV 28", V6000, DVD1, BC9000, BS3000, BL4000, MX4200, CX50, BeoCom 2, Beocom 6000, LC1, LC2
Last production version was 3.1 you can get a futher upgrade if you need to record from a STB in a particular configuration. Version 2.0 and above was OK. There possibly was a parts kit upgrade before that from memory...
BTW Check the Antenna mount on the back. Some come loose if stiff antenna cable is used.
What are you connecting it to?
Beoaus.
