Hi all,
I'm just curious how we can find out a Beosound 2's production period and location.. seems to be a stupid question? =p
Here are two of the serial no.: 92117666, 92401733
Thanks heaps for your kind help!!
Cheers,yat
The Beosound 2 was introduced in 2002.
There appears to be something incorrect about the serial numbers you stated because the first two digits normally define the year of manufacture, with this year being 21 !!
Regards Keith....
Serial number 92401733 was supplied to a dealer July 2002
Serial number 92117666 was supplied to a dealer November 2005
Hope that helps.
Hi Yat
If I told you, I would have to shoot you and I don't want to do that. Glad I could be of help in this instance.
Opman
