Latest post 04-05-2008 9:59 AM by marrow999. 2 replies.
Page 1 of 1 (3 items)
  • 03-31-2008 6:54 PM
    Beocenter 2 connected to Beosystem2 - unable to pull up CD or radio on the remote.??
    I will not muddle this query with my already confused B&O head  - my beocenter is connected to the AV Scart input on the Beosystem2 - in the Connections menu I have AV set to DVD so rather unsuprisingly when I select CD on the Beo4 it ignores it (same for radio). My Skybox is in the Vmem scart, with a Beomedia on the VGA input.
    How can I change this to allow me to access the CD and radio from the remote? Do I need the Dig out
     Many thanks
    Mark
  • 03-31-2008 11:07 PM In reply to
    Re: Beocenter 2 connected to Beosystem2 - unable to pull up CD or radio on the remote.??
    Are your option settings correct? Assuming the speakers are connected to the BS you need to switch the BS to option 2 and the BC to option 0 if I am not mistaken.
    I think if the Beosystem is in option 1 and the BC 2 is in option 0 which it goes to if no speakers are connected then it behaves like you describe - I leaving the TV/Beosystem in 1 and the BC in 0 which is an invalid combination.
    This all assumes your speakers are connected to the BS.
    http://www.beoworld.org/beotech/mlsetups.htm
    Here is how you change options. I hope I am not too far off, this is new for me but my BV8/BC2 behaved similar when I did the initial setup.
    Cheers
    JK
  • 04-05-2008 9:59 AM In reply to
    Hi JK
    Huge thanks for that - absolutely spot on even with your assumptions!
    All working well now
    THANK YOU
    Mark
