Latest post 03-14-2008 3:12 AM by londonguy. 4 replies.
Page 1 of 1 (5 items)
  • 03-13-2008 3:05 AM
    Re Avant DVD
    Hey guys,
    Strange problem, my Avant DVD switched off yesterday afternoon whilst my father was watching a show. When i press any of the buttons suchs as 'tv', 'sky' or 'power' it takes along time to react and doesn't show a picture. Haven't been able to get it working. Has this ever happened to anyone? Or any ideas of what could be wrong?
  • 03-13-2008 6:36 AM In reply to
    Re: Re Avant DVD
    Is it connected to anything else? Have you done a hard reset? - unplug and leave for 5 minutes and then restart- you will need the PIN. Might be a minor component failure so probably time for a service.
  • 03-13-2008 6:42 AM In reply to
    • darren
    • Top 500 Contributor
    • Joined on 03-28-2007
    • Netherlands
    • Posts 164
    Re: Re Avant DVD
    I had a similar problem last year when I was playing with my link set up. It was a loose connection in my ML cabling.
    If your Avant is connected via masterlink then I would recommend disconnecting this temporarily if the hard reset which Peter recommends does not resolve the problem.
  • 03-13-2008 9:46 AM In reply to
    Re: Re Avant DVD
    Hi there Peter and Darren,
    My avant is connected via masterlink to an Overture. I will try the system reset when i get home and will also try disconnecting the the masterlink and let you know how i get on.
  • 03-14-2008 3:12 AM In reply to
    Re: Re Avant DVD
    Hey guys,
    Tried turning it of for 5 mins and then turned it back on, it asks for the pin but when i type it in on the remote it doesn't seem as though its getting through to the T.V. Also, disconnected the masterlink and it didn't a difference.
    Thanks for your help guys, i've got an engineer coming out today, so hopefully the problem will be resolved soon.
