Latest post 03-18-2008 8:32 PM by jk1002. 1 replies.
Page 1 of 1 (2 items)
  • 03-18-2008 8:24 PM
    Connecting Airport Express to BC2 using Optical cable
    Is anyone able to tell em whether you can connect an airport express via an optical cable to a BC2 socket box. I have an ordinary analogue Aux. A. connection between the two and that works fine. I am wondering whether I can change this to optical digital to improve the sound. Am I also able to use the S-video on the BC2 Socket box to do the same thing - play music fro my computer to the B&O system. Do I just purchase an optical digital cable from an electronics shop?
    Many thanks
    Patrick
  • 03-18-2008 8:32 PM In reply to
    Re: Connecting Airport Express to BC2 using Optical cable
    the optical is an outbound connection if i am not mistaken. for airport express you need inbound.
    jk
