Hi, I've got a Mk2 Beocom 6000 which I want to try and adapt for use with a bluetooth headset. I've found a very small bluetooth adaptor to use but it needs a 2.5mm socket to plug into. Has anyone ever put a socket on a handset? Alternatively maybe a modification could be made using the jack from the B&O earset. Any advice would be most gratefully received.
 thank you
Richard
