Ive just been listening to my "new" pentas. They sounded really good at first, but when i turned them off and moved them after a few hours one of the amps began making a loud buzzing sound just like a large transformer does. This buzzing sound can also be heard from the speaker elements themselves, but not as loud as from the amp/ps.
The sound returns when i turn the speaker off, and turn it on again.
Could this be the sound of one of the capasitors on the amp or power supply dying? If so, where should I start replacing first?
The speakers are connected to a pre-amplifier through the line in port. I have tried disconnecting this line, and the sound continues until the beolab turn itself off.
I have not tried using the powerlink, since I don't have my Beocenter here at the moment.
I appreciate any input. :)
-Magnus
Update:
When I turned them on this morning everything was back to normal. This does support my capasitor-theory, doesn't it?
