Latest post 02-29-2008 11:41 AM by Keith Saunders. 0 replies.
Page 1 of 1 (1 items)
  • 02-29-2008 11:41 AM
    New updates and additions to the Beo5 Information & Resource Downloads
    We are pleased to inform you that the Beo5 Information & Resource Download page HERE has additions and updates as follows:-
    1. The French Canal Channels have been updated with added channels and channels which have been moved by Canal. In the ZIP file are additional Logos and a new XML template. If you have previously downloaded and extract the content, then when you extract it again WINZIP will ask you if you want to replace the files and you should say YES.
    2. There is also a new template for Lutron light systems including support for the Grafik Eye 3000
    I want to take this opportunity to thank Yann Gourrier in France for providing me with the French updates.
    So, go to the download page HERE
    Regards Keith....
