Latest post 04-07-2008 1:23 PM by Keith Saunders. 6 replies.
Page 1 of 1 (7 items)
  • 04-07-2008 11:59 AM
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Problem with my MX5500
    Recently I have been having some problems with my MX5500. When I try to watch a DVD I get a interference on the picture. At first I assumed it was the DVD player, I was wrong. So then I tried anothe Scart lead, still the same. Although by accident I pulled the Scart lead out from the STB, the picture was then perfect. It then occured to me that the problem only started after I went froma freeview box over to cable. However the picture from the STB is perfect. HAs anyone else come across a similar problem?
    CraigSmile
  • 04-07-2008 12:03 PM In reply to
    Re: Problem with my MX5500
    Sounds like interference from two many items connected to the televison. Have you tried turning the freeview/cable box off when turning the DVD on?
    If this is the problem you mean that should cure it.
    Graham
    PS Standby will do.
  • 04-07-2008 12:17 PM In reply to
    Should have said too many - have been typing like a muppet all day!
  • 04-07-2008 12:21 PM In reply to
    • Craig
    • Posts 4,855
    Even if the STB is in stand by it still causes interference. Don't think it is too many items as I only have the STB and DVD caonnected and there are two Scart sockets.
    CraigSmile
  • 04-07-2008 12:43 PM In reply to
    It sounds like an earth loop problem through the Cable STB.
    Is your cable STB connected to the cable system via a Galvanic Isolator ?
    I will answer your next question before you ask it.. What is a Galvanic Isolator ?
    A Galvanic Isolator allows the cable signal to the STB without the associated ground link to avoid ground loops or other electrical potential differences, the Galvanic Isolator MUST always be used when you are connected to a cable system.
    Regards Keith....
  • 04-07-2008 1:16 PM In reply to
    • Craig
    • Posts 4,855
    Keith Saunders:
    Keith the cable STB is setup just as it was installed. All I have done is move it from one Bedroom to another. What does a Galvanic Isolator look like?
    CraigSmile
  • 04-07-2008 1:23 PM In reply to
    Craig,
    To prove if the cable is causing the earth loop, I suggest you leave the SCART cable to the cable modem, but disconnect the cable to the cable company. If the DVD picture is good then you will need a Galvanic Isolator, if you still have the problem then the earth loop is being created somewhere else.
    At this stage I suggest you just remove the cable from the cable STB
    Regards Keith....
