Latest post 02-23-2008 8:36 PM by Medogsfat. 1 replies.
Page 1 of 1 (2 items)
  • 02-23-2008 6:39 PM
    In need of help, please!
    Hi All,
    I have a BeoCom 6000 Mark 1 and for the past few weeks I have experience a slight problem, which I am not sure how can I fix it.
    The red light on the phone keeps flashing constantly and I am unable to stop it. Originally started when I had a miss call on my phone and even thought I had view the missed calls the star next to the number did not go away. I also when to the menu and stopped the light but that did not work either as the red light still continued to flash. Finally, I when to the B&O shop and the salesman resetted the phone, but the red light is still flashing.
    Could anyone please help me as I am not sure whats the actual problem still and also how can I fix it.
    Thank you
  • 02-23-2008 8:36 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: In need of help, please!
        from your description it sounds like the caller ID function telling you that you have a missed call. If you aren't subscribed to caller ID then you need to cancel the function in the set up menu. If you do have caller ID then simply press the relevant small triangular button at the top of the keypad until you see a number marked as "new call" then press the "C" button and that should stop the red flashing light. If you have more than one missed call then keep pressing the caller ID button until you clear them all.
    Chris.
