Latest post 03-14-2008 4:01 AM by Bulgarien. 3 replies.
Page 1 of 1 (4 items)
  • 03-13-2008 5:13 PM
    Remove Penta frets???
    Hi!
    How do I remove the frets on a Penta speaker?
    /Ola
  • 03-13-2008 5:20 PM In reply to
    • camshaft
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Pennsylvania, USA
    • Posts 575
    Re: Remove Penta frets???
    I don't have pentas (yet, at least Smile ) but from what I remember, there are plastic tab clips going around the frets that snap into the speaker.  You have press each tab starting at one end and unsnap them.  Might want to wait for someone else to chime in since as I said I've never done it myself though.
     Austin
    -Austin (resident audiophile skeptic)
  • 03-13-2008 6:04 PM In reply to
    I took a thin knife and pressed it in between the frets and the speaker and then bended softly and it snapped of clip by clip. Don't know if it's the right way but it worked anyway. =)
  • 03-14-2008 4:01 AM In reply to
    • Bulgarien
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Denmark, Vest Sjaeland
    • Posts 201
    Don´t!!
    Do anything with a knife!
    Just feel where the plastic clips are and then pull out the cloth.
