Latest post 03-13-2008 5:59 PM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 03-13-2008 4:36 PM
    problem with tape of my beosystem 2500
    dear all, I am the owner of a beosystem 2500 and yesterday, the tape refuse to work.
    Did someone have the same kind of problem? I think it's a belt that I must change.
    Did someone ever repair it by himself? Did you know where I can find the service manual?The belt?
    thanks for your comments.
  • 03-13-2008 5:30 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: problem with tape of my beosystem 2500
    There seems to be more than one version of tapedecks used in these machines. I can supply belts for one of the version, the version II.
    Take a look at the attached photo to determine if the belt kit I have, will fit.
  • 03-13-2008 5:35 PM In reply to
    many thanks
    this is the first kit (without screw). Did you know where i can find the kit and how change it?
  • 03-13-2008 5:59 PM In reply to
    • Dillen
    • Posts 5,008
    I can supply those belts, three belts in total if my memory serves me right, but I don't have mounting instructions for the Beosystem 2500.
    I have mounting instructions for Beocord 3500/4500 and since the tapedeck is the same, the only difference would be how to gain access to the deck.
