Ok,
This weekend and with much planning and thought process i will start to chase out the walls in my lounge for wiring up and masterlinking my system (they will be buried in such a way that i can hopefully remove in the future if necessary). I have everything ready to go except for an AM Loop for the BS9000.
What i need to know is if there is a special AM loop for the 9000 that is suitable for burying in the wall? I would like to run it up through the wall and just leave the end between the lounge ceiling and bedroom floor. Do you think this would be OK for getting a good AM signal and if so can someone point me in the direction of the correct AM cable.
Thanks Gang
Mark.
Never Mind The Ball-Cocks
www.markmossplumbing.co.uk
A labourer uses his hands
A tradesman uses his hands and his head
A craftsman uses his hands, his head and his heart
