Latest post 02-05-2008 5:29 PM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 02-05-2008 4:05 PM
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Sky Box & MX5500
     Is there an STB for the MX500 that will control a standard Sky box? My plan is to get another Sky box for the Bedroom, I would like to control in using my Beo4. As I do with my BV3-32 downstairs.
    CraigSmile
  • 02-05-2008 4:25 PM In reply to
    Re: Sky Box & MX5500
    I don't think there is. But if you link the MX to the BV3, you can use the Sky box attached to the BV3 and control it from the MX.
  • 02-05-2008 5:10 PM In reply to
    • Craig
    • Posts 4,855
    Perfect solution I know Peter, and here is the problem. Our Landlord will not allow us to channel any wiring into the walls. Is there an STB for the MX6000?
    CraigSmile
  • 02-05-2008 5:29 PM In reply to
    Yes - the same one as the AV9000 - might be tricky to find though. No longer on the ROS.
