1st March February 2012
Latest post 05-01-2007 3:38 AM by soundproof. 24 replies.
04-30-2007 6:50 AM
DavidStewart
- Joined on 04-30-2007
- Posts 7
Hi all,
Could you give me some advice please. I was in my local branch of B&O at the weekend (great service) and have been sold on the Beosound 9000 and the Beolab 4000 speakers. I am limited really in the speakers as the other half wants them to be wall mounted. I was just looking for some opinions (or other possible options) on the speakers would they be good enough as a starting point as I plan to build on what I purchase just now.
marcus_m
- Joined on 04-16-2007
- Bavaria
- Posts 470
TDB: don´t get the 4000s, forget the other half and go for the 6000 or BL3. much better choice.
Sorry, can not fully agree, the 4000 have a much better sound than the 6000, especially when wall mounted. The BL3 would be the first choice, but have a much hugher price tag.
soundproof
- Posts 2,340
DavidStewart: Hi all,
It depends upon the kind of music you enjoy listening to. The BL4000s are probably the most underestimated of B&O's speakers, they are powerful relative to their size, have a very true soundstage when placed properly and blend in elegantly. I have several musician friends who swear by them because of their sound. An alternative, if wall mounting is a requirement, is the BL3s. They would be an upgrade relative to the BL4000s, as you get the benefits of the acoustic lenses. But while you can push the 4000s to the top, without distortion, you'll find that the BL3s will reach a plateau where they muddle up somewhat, if you're running them from a BeoSound 9000. I'm a fan of both models. Excellent sound relative to their size.
DavidStewart
- Posts 7
Would a good configuration be the Beolab 4000s mounted on the wall behind me (either side of our couch) and the Beolab 3's on the other side fo the room ? Would the Beosound be able to support the 4 speakers?
Foxtrott
- Vienna, Austria
- Posts 500
Hello and welcome to the forum! In my opinion Beolab4000 are still a good choice when entering the B&O World, for their size they perfrom well and can always be used as rear speakers in a 5.1 setup or also as front speakers if you plan to upgrade to a B&O TV. If you are limited to wall mounted speakers then you should also consider a pair of Beolab3 (if your budget allows them). Beolab3 can also be wall mounted and outperforms the Lab4000 in terms of clarity and sound details. Cheers Foxtrott
"The first thing we do, let's kill all the lawyers." Henry VI, Part 2 William Shakespeare
easyJan
- Belgium
- Posts 13
I just finished installing B&O in my house and am really impressed by the Beolab 3's. Wonderful little devils of speakers. They are very comparable to my BL8000, which I still find the best looking speakers ever seen -and they only take a minimum of floor space. I am even very pleased by the BL4's that do a very nice job as link speakers in bed-and bathroom. However, I think they will do unjustice to your BS 9000 as main speakers. This probably counts for the BL 4000's too, but I have to admit i don't know these very well. Someone else can probably help you out on them. After all, just go for you own taste -and that of your other half if needed, as far as your budget allows (and be careful, with B&O you get beyond it vèry easy). Jan
DavidStewart
- Posts 7
Budget isnt a problem - when I say isnt a problem I mean I can spend in the region of 500-1000 more on my initial purchase. I plan on adding to it in the near future and this was my plan. Initial Beosound 9000 with the BL4000s mounted then in 3-4 months time buy the Beolab3's for front speakers and a Beolab 2 ( I think ) for my sub. I already have a 40 inch HD Lcd from Samsung so that will need to do for the time being. Is this the way I should be going or is there a better\different path.
Graeme
- Aberdeenshire Scotland
- Posts 194
I think your idea of starting of with the 4000's is best for wall mounted. Although the 3's are better sounding speakers, I dont think they are good wall mounted unless great care is taken in setting them up. The accoustic lense makes the sweet spot for good imagery very small, however mounted on the floor stands at sitting hight they are outstanding.
Cheers
Graeme
Peter
- Joined on 02-12-2007
- Posts 9,572
The most important thing to do with speakers is to listen to them yourself. We all have opinions, as can be seen above. I think the Beolab 4000s are the most under rated speaker in the range and think they are superb. I have a pair of them and a pair of Beolab 3s, and although the Beolab 3s are superb at low to medium volumes - better than the 4000s - the 4000s play louder before starting to muddle than the 3s. Your plan seems a very good one. But have a listen first comparing 4000s and the 3s. The 4000s have just been updated with ICE amplifiers which I have not heard yet so make sure you hear the type you would be buying.
The Beonic Man
- Bath
- Posts 426
It is a very personal choice at the end of the day but I have to say I am a big fan of the BeoLab 4000 speakers. I love their design, especially the placement of the LEDs which turn green when switched on and of course red when switched off. One of them also acts as a power on/off button which I think is very cleverly thought out. They produce fantastic sound there is no question of that. I looked at these years ago, and more recently because I am also going to buy a BeoSound 9000 and will need some speakers to compliment it, so the very fact that they are still such great speakers after so many years says so much about what you get when investing in a B&O product, they are timeless. I personally would choose them over the BeoLab 6000s which are weaker in comparison in my opinion. I would also choose them over the 6000s from a design point of view. However, the BeoLab 8000s and the 3s (with acoustic lens technology) are more powerful but it depends on the size of your room and how much power you want. Remember that the B&O concept is about furnishing - fitting in as much as looking and sounding the part - so choose what you think best compliments the rest of your room and indeed your house when considering upgrades for the future. The 4000s are a perfect choice for the BeoSound 9000 and look great when wall mounted. If wall mounting wasn't the option then I would have seriously considered the 8000s (which I already have) because these speakers are arguably the most famous of the B&O range for all sorts of reasons. Having said that, so many B&O products have stood and continue to stand the test of time, so that means whatever you buy will never sit around collecting dust or become obselete, you will simply swap and change things around as your collection grows. I hope that has been so some help. You really won't go wrong with whatever choice you make. All the best, Simon.
"We can rebuild him. We have the technology."
7-40, 7-2, 9000, BS3, BC2, LC2, BC6000, Beo5
GSHaigh
- North West UK
- Posts 163
Hi I started with a pir of BeoLab 4000's and I haven't moved on from them.... while I can hear the clarity of the BeoLab 3's I personally can't justify the additional cost. I now have another 2 pairs of 4000's in the house. I have however added the BeoLab 2 sub to my main room setup, but mainly for movie watching. I'd consider buying the BL4000's, you won't be disapointed and then if at a later date you fancy a change you can alway move them to a nother room and link them. Greg
easyJan
- Belgium
- Posts 13
The only good path is your own. But don't be afraid to change it to find a better way. We were planning to renovate a part of the house. As I was going to do the cablework for the hifi-system myself, we decided to install that first to avoid breaking up walls and floors after the renovation. The initial plan was to add two speakers to the 11 year old 28"Avant, connect a radio/cd-player, have speakers in the kitchen and possibly an extention to the bathroom later on. It ended with a new -possibly the last one sold- 32" Avant (old one broke down in the meantime), linked to a BS 3200, 4x BL 8000 + BL 2 in surround setup, BL 3 in the kitchen and BL 4 in bed- and two bathrooms and Bose 'dug-in' speakers outside. No, I don't want to show off with my B&O, I have to work very hard to afford this kind of foolishness. The point is, I want to do things properly once I start them (hence it took me 8 months to finish all those hidden cables in my little free time), and you may negotiate better conditions with your dealer. I am very happy with the end result now.To me it was worth the sweat and the money. In short, I should have said, go for the BL 3's now(they're better) and add BL 4000 later on if you want. Good luck with your choice. Jan btw I am still dreaming about BL 5's though
DavidStewart
- Posts 7
Thanks for all your helop and advice. I'm going back in tomorrow so I'll ask to test drive both the BL3 and the 4000's. Will the Beosound 9000 be able to handle all 4 speakers?
Sorry for all these questions but I am total novice when it comes to B&O
Ryan
- Joined on 04-17-2007
- Toronto
- Posts 29
So many opinions, so few facts. Anyway, I feel that someone should point out that while the beosound 9000 will drive 4 speakers, it will only do that with two channels. If you were hoping to get cinema surround sound out of this setup then you have to double the expenditure and incorporate a beosystem 3 or b&o television. This is one area where b&o have a lot of work to do (incorporating 3rd party screens). You could always do what I did and just live with stereo sound instead of 5.1 channels.
SWISS_2
- Neuchatel, Suisse
- Posts 552
Good Morning. I know you both have had about 10+ hours to think this over last night, but I would suggest you enjoy a bit more time with your B&O sales staff today. Take time to listen to each of the speaker options, and don't be rushed. The BL 4000 has excellent sound, can be mounted vertically or horizontally, or moved about later in and around your sound room. I have a Gold pair that were originally wall mounted, then tried out on the metal stands, and finally placed later on either side of a 42 Plasma as a Home Theatre / Stereo system. Both look and sound just great. The speaker units sit ontop of the black speaker stands by B&O, but also look equally stunning on masonry, brick, granite, teak, in a bookcase, and even on top of well weathered wood. You can see many of these images at this website, in the catalogue and elsewhere. Given your investment in the BS 9000 system, the very minor inclusion of a Beoport ( or posssibly Beomedia ) is also something you might look into when you are there today. This wiil further enhance and integrate your system with PC or MAC Photos, Video, N.Music( MP3 ), and about 6000 + Internet radio station choices to enjoy. All with your Beo4 remote. Let us know how it goes today.
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
We have two sets of 4000s, one set on stands and one set as speakers for our computer. We also have a set of Beolab 1 and 6000s in a surround sound setup. Sometimes when I want to listen to music, I actually prefer the 4000s over the 1s. The 1s have more detail but sometimes the 4000s just sound better to me. I agree they are fantastic speakers. That said, I would like to try the acoustic lens technology and have been toying with replacing the 1s with 9s or the 4000s with 3s. I would have to be convinced that they actually did sound better and that would require hearing them in my own home instead of just at the dealer.
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
Peter
- Posts 9,572
Ryan: So many opinions, so few facts. Anyway, I feel that someone should point out that while the beosound 9000 will drive 4 speakers, it will only do that with two channels. If you were hoping to get cinema surround sound out of this setup then you have to double the expenditure and incorporate a beosystem 3 or b&o television. This is one area where b&o have a lot of work to do (incorporating 3rd party screens). You could always do what I did and just live with stereo sound instead of 5.1 channels.
I did!!
soundproof
- Posts 2,340
When I pick speakers I consider the materials in the room they will be in (hard surfaces, wood, textiles, large windows, etc); the size of the room; the kind of music I will be listening to (or is it for movie viewing?); possible distance between speakers; distance from my ears to the speakers; and the space behind my head (potential reflections);etc. Personal preference will play a part. And sometimes you choose with the eye, instead of with the ear. Which probably accounts for some of the responses in this thread - clearly, we're different! In the present B&O range, I would prefer BL5 to anything, if you have the space to do them justice. (To work their best, they should have air around them. Moulton recommends up to two meters to any wall to avoid any unwanted reflections). BL9 over BL1, because they deliver as true a soundstage (at least) with the added benefit of the acoustic lens. Also, the BL9s have the hybrid amplifiers for the mid and top drivers - if you listen to acoustic music (i.e. not processed/mixed but straight from performers to recording medium) you'll notice the advantages of that.
BL3 over BL8000 - because of the acoustic lens. The 8000s are great speakers, yet I find myself increasingly impressed by the benefits of these lenses. The BL3s have a weakness when you push them, but I have never had a problem with that, as I have other speakers I would use for loud listening. I am particularly fond of the BL4000s - they have a "true sound" quality that I like. I'm not sure whether that is because the shape and weight and size of them are "perfect" for what they are supposed to do, but their sound does stand out, in my opinion. The woofer driver is larger than in the BL6000 and 8000, the tweeter drivers are the same size. But the column speakers "compensate" by having two woofers -- still, it's almost as if the 4000s have a more solid definition of the sound - to my ears. Risking the ire of B&O I would not use BL9s as rear speakers, because they are floor standers. Ideally, you want side and rear speakers up on a wall for movie listening, to provide an unobstructed soundpath to your ears. BL4000s or BL3s are both great for that. And to those who claim that one should have similar speakers all around: almost no music is produced that requires that, and no movies are - so it would really beg the question "Why?" There are better ways of spending that money if the goal is to create a great home cinema, for instance.
I do not like using independent subwoofers for music listening - it often introduces an artificial boominess that has nothing to do with performance sound, and therefore is just bothersome to my ears. But that's probably also because I almost exclusively listen to acoustic music. The BL5s have an incredibly precise bass, calibrated to the volume of the room and its reflective properties - it is also capable of applying power "just so" - which means the BL5s bass rendition is true to the acoustic performance. (And also why some are dissatisfied with it if they want to shake and rattle the walls.) In musical genres where the bass is a feature, you'd want a subwoofer with some of these loudspeakers. Though you shouldn't need it with the BL9s and definitely not with the BL5s unless you're a bass maniac.
Page 1 of 1 (25 items)
