Latest post 12-23-2008 12:57 PM by tournedos. 3 replies.
Page 1 of 1 (4 items)
  • 12-23-2008 10:43 AM
    • MizZoo
    • Not Ranked
    • Joined on 12-23-2008
    • Posts 2
    Beovox S 45-2 resistors
    Hello everybody,
    I recently bought a pair of Beovox S 45-2 speakers at some junk sale for $5. I found out that there were some resistors burned (big suprise), and I need to find out which ones these are to be able to replace them. They are burned, as I said, so I can't read the resistance. They are the two resistors connected to the tweeter. Could anyone fill me in on which resistors I need to buy to replace these burned ones? Any help is appreciated.
    (I am not a technician, and I'm from the Netherlands, so I hope I explained everything clearly enough for you guys to understand.)
    Thanks!
  • 12-23-2008 11:46 AM In reply to
    Re: Beovox S 45-2 resistors
    The one in parallel with the tweeter (R6) should be 8.2 ohms / 3W, and the other in series (R5) is 1 ohm / 3W. Hope the tweeters themselves are OK - these are good speakers, and well worth repairing!
    Also - welcome to Beoworld, and happy holidays Smile
    -mika
  • 12-23-2008 12:24 PM In reply to
    • MizZoo
    • Not Ranked
    • Posts 2
    Thank you very much for the info. Is there any way I can test if the tweeters themselves are still working?
    Happy holidays to you as well!
  • 12-23-2008 12:57 PM In reply to
    Measure the coil resistance with a multimeter. If it shows infinite instead of a few ohms (1-8), the coil has probably burned...
    But even if it is, don't despair! The 45-2 woofers have a habit of breaking in transport, so some fellow Beoworlder might have spare tweeters looking for a new owner. Since you got the boxes almost for free, it might still be viable to invest in spares.
    -mika
