Latest post 01-26-2008 9:50 AM by tychoma. 2 replies.
Page 1 of 1 (3 items)
  • 01-26-2008 9:34 AM
    Beomaster 901 UK mains issues - help please!
     I recently acquired a Beomaster 901 amp and Beocord 900 tape deck from my family, but am unsure of what I need to connect it to the mains.
    At the moment the power cable is a 250v, 6amp connector with three parallel pins (Made by 'Masterpiece, England' apparently) with BS5733 written on it. Do I need a step-down converter to get it to 240v? Can I just lop off the plug and fit a standard plug?
    We've been without an amp for weeks now and can't take it any longer!! Any help greatly appreciated :)
  • 01-26-2008 9:45 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beomaster 901 UK mains issues - help please!
    Welcome to Beoworld !
    The Beomaster 901 has a voltage setting switch underneath.
    Make sure to set it to 240 V and you should be home free with a suitable plug on the lead.
    The 250V marking on the plug is merely a "max rating".
  • 01-26-2008 9:50 AM In reply to
     So it does! Thanks Dillen, I'm off to set up the living room again Big Smile!
     Also thanks for the welcome, there's nothing like a friendly forum that can also answer questions :)
