On Monday I hopefully will be getting a new update of the STB-C list for my BV9 after it mysteriously dissapeared a few days ago. In fact after the service technican performed the update last time the BV9 indicated a flashing red LED on the ON/Standby LED which I interpreted as a problem. We turned the BV9 on and off once again and the flashing LED symptom dissapeared, but cam back a few times.
On Monday I will get a new STB list installed as well as the latest BS3 software 4.0.
A few questions:
1: The flashing red LED, does this indicate a problem, and has anybody else experienced this
2: Could it explain the loss of the STB list from flash
3: Does any body have the lastest STB-C list of devices managable. I want to be able to pick my current and also potential new products from the overall list and have them installed even though I do not have them at the moment, to avoid repeated technical calls.
I know that Peter had said last year that he was going to publish the list in the Television section but I cannot find it.
Regards
Rolf
