Latest post 01-07-2008 8:59 AM by Baolu. 3 replies.
Page 1 of 1 (4 items)
  • 01-04-2008 11:30 AM
    • Doc
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 585
    1x1 logo's, instead of 3x3 or 4x3
    I would like to repeat the question of Baolu, and make a new post of it:
    Can anyone rewrite the BeoConfigurationTool-software so it's possible to get 1x1 picture?!
  • 01-04-2008 1:45 PM In reply to
    • banger2004
    • Not Ranked
    • Joined on 09-13-2007
    • Clanfield Hampshire
    • Posts 14
    Re: 1x1 logo's, instead of 3x3 or 4x3
    Hi Doc!
    I use a single BMP image for the opening zone screen on my Beo5. I just increased the pixel size of the image. It took a few guesses to get the size exactly correct but looks good.
    I've also used a single BMP image for channel slection on my Beo5 for sat. My four year old son uses the Beo5 to change to Cbeebies etc, and knows the logos rather than the channel numbers. I placed the single button with IR code in the middle of the screen and assigned the logo after resizing it. Hey presto, it now takes up most of the screen and he just presses it in the middle to work it! I then used another 'page' to do other channels!
    Banger2004
  • 01-05-2008 1:45 PM In reply to
    • Doc
    • Posts 585
    Hi Banger2004,
    Which pixelsize did you make the picture in the opening zone-screen?
    Doc
  • 01-07-2008 8:59 AM In reply to
    Hi Doc.
    Thanks for your new thread.
    Only one logo does not work. Its always a little logo.  Which Software Version have you used, Banger?
    Baolu
