My MX3500 has a strange behaviour on power-up. Is it normal?
On all my previous (non B&O) TVs, the picture faded up, a few seconds after power-on. However, on my MX3500, about two seconds after power-on, I get an all grey raster, with vertical retrace lines visible. A second or so later, this fades away, to leave a good picture, with no retrace lines visible.
To me, this suggests that the set is feeding extra current somewhere on power-up (most likely grid G2, or cathodes) and then backing off to a normal level. Do these TVs do this to get faster start-up? If so, are the visible effects meant to be suppressed somehow, or is the behaviour normally visible?
Of course, it could be a faulty TV!
Mark
p.s., If I've used the wrong forum please tell me - it was hard to decide between "Workbench" and "Vintage".
