I have heard from a source that B&o have produced a new digital "masterlink" port with the use of CAT-5 cabling..
So you can send all the video and audio signals in 1080p and 7.1 in one thinner cable than the old analogue masterlink (composite and stereo signals only)..
It´s sounds good to me, but it also means that i and every one else have to buy a new highly expensive system that is compatible with this new Digital-Link system to get benefit of it
Why can´t they use the HDMI as masterlink instead? Why most B&o always go by their own and take the long way around instead of the shortest way troug..??
And i think most likely the new Beosound 5 and other new products that coming up in 2008- will be equipped with this new Digital-Link port.
Regards
