Latest post 01-07-2008 3:40 AM by joeyboygolf. 5 replies.
Page 1 of 1 (6 items)
  • 01-06-2008 8:57 AM
    • pgriep
    • Not Ranked
    • Joined on 01-06-2008
    • Posts 2
    volume control beosound 3200v
    Goodday; I have the beosound 3200, but not the remote control yet.  When I try to adjust the volume on the beosound it doesn't work; when I go to the option; then sound it displays "use tv"  I have also seen this in the user's manual; then I'm supposed to adjust this on the tv or video.  However I don't have this hooked up at all.  Does anyone know how to set the beosound in such a way it doesn't do that?  Or any other way to adjust the volume on the beosound?  Thank you very much, Paul
    Filed under:
  • 01-06-2008 9:34 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: volume control beosound 3200v
    It sounds like it's in the wrong option mode, but how you'd fix this without a remote, I don't know!
     Weekly top artists:
  • 01-06-2008 10:05 AM In reply to
    You need to run test mode 37
    Place the unit in test mode like this
    Wait 20 - 30 sec. after connecting to mains.
    By means of keyboard from St.by mode: Press Display 0 2 5 8 with no more than 2 sec. between the individual enterings.
    Then enter 37
    Press Standby to exit testmode.
    Option setting will be returned to 1 and you will have normal keyboard control.
    CD memory should not be affected.
    Regards Graham
  • 01-06-2008 12:03 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    joeyboygolf:
    Then enter 37
    This is why Graham is a technical advisor.Wink Now I would have thought without the remote is was impossible, but you live and learn.
     CraigSmile
  • 01-06-2008 6:22 PM In reply to
    • pgriep
    • Not Ranked
    • Posts 2
    This worked perfectly!  Thanks so much for your help; really much appreciated,   Paul
  • 01-07-2008 3:40 AM In reply to
    No problem and welcome to BeoWorld!
    Regards Graham
