Latest post 01-04-2008 5:20 PM by david707. 2 replies.
Page 1 of 1 (3 items)
  • 12-29-2007 12:47 PM
    S Video on LX5500
    I have a DVD1 connected to an LX5500 but cannot access the S Video signal via Shift+9. I get a blank screen. Can anyone advise me of the reason for this? I have tried a Hi8 VCR also with S output and nothing from that also.The scart from the DVD1 is connected via an AVX-1 expander to AV2 and works fine
  • 12-29-2007 8:11 PM In reply to
    Re: S Video on LX5500
    From the pile of MX/LX sets i've repaired i learned that with 9,5 out of 10 of these tv sets the solderings at the back of the s-vhs connection are loose, i'm sure this is the same with your's (so a bit of minor surgery would be needed).
    You could try to slightly pull/turn the jack a bit in the connection while looking at the screen and see if something happens...
  • 01-04-2008 5:20 PM In reply to
    I have now traced this problem to an intermittent problem with a lead. A new lead works fine.
    Thanks for the reply.
    David
