Latest post 03-01-2008 10:00 AM by royles69. 2 replies.
Page 1 of 1 (3 items)
  • 02-28-2008 4:46 PM
    BEO SYSTEM 9500
    I have a 9500 centre that i was listening to and it powered off with no lights on and won't power up again yet the penta speakers make a noise when i plug the system in ? is this a fault anyone knows anything about or knows how to rectify ? please help
    Filed under:
  • 02-28-2008 5:39 PM In reply to
    Re: BEO SYSTEM 9500
    If you remove the cover from around the voltage selector you will find 8 fuses. Worth checking these first. You will need a Multimeter.
    CAUTION Unplug from mains supply first!
    Regards Graham
  • 03-01-2008 10:00 AM In reply to
    Re: BEO SYSTEM 9500
    will do thanks
