Latest post 12-29-2007 9:20 AM by beolife. 1 replies.
Page 1 of 1 (2 items)
  • 12-29-2007 8:43 AM
    Beosystem 3 -useable with Third Party Panels?
    To be honest,having searched the forum,I am confused as to whether it is possible or not.
    In general,can the Beosystem 3 be used,and is it fully compatible,with a third party panel?
    Specifically with  Pioneer 8G model?
    If not fully compatible,what are the areas of omission?
    Thanks.
  • 12-29-2007 9:20 AM In reply to
    Re: Beosystem 3 -useable with Third Party Panels?
    If your planning to buy a screen to go with the beosystem 3 then you should think about the new 7-40 as this incorporates the BS3 & also includes a built in DVD so on my workings this is much better value than just buying s BS3 on it's own.
    This is what I am planning to do in the near future to replace my BS2 with lots of extra connectivity & facility to run a projector etc.
