Hi Doc!
I have a start logo on my Beo5, but only have one room in which the system works so don't have multiple zones. I downloaded the photo from the B&O website - I used the picture of the top of a Beolab 5 - then resized it using Pixresizer.
I then looked up properties on the 'Lounge' button on teh Zones page and added the logo as I would for a TV or radio station.
It was then necessary to resize the image a number of times and move the button around to see where the picture looked best!
The only problem is that the logo hides the word Lounge, so it's a bit of guess work as to where it is, but you soon get use to it!
There is a Beoworld member who has taken a photo of the front of the lower half of the Beo 5 and sectioned it into three - maybe corresponding to the three rooms he has the system? Try and have a look - it looks fab!
The above is how i've done mine and it looks good. Maybe there is a better way - anyone help?
Paul
