Latest post 12-20-2007 4:56 PM by Alex. 1 replies.
Page 1 of 1 (2 items)
  • 12-20-2007 4:53 PM
    TV tuns on automatically. Help!
    Please excuse me but I have asked this question before and cannot either eremember the answer or find it on the forum. I have BC2 connected to an Avant. If I leave the DVD munu running for a while the BC2 will turn off and the TV turns on by itself! A bit unnerving if it does it when you don't expect it.
    I thought it was an option problem but I have reset the options: A Opt 2, V Opt 0. Can anyone give me a hint as to how to fix it.
    Patrick
  • 12-20-2007 4:56 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: TV tuns on automatically. Help!
    Under the connections menu for the BeoCentre 2 socket (whichever one it's in), you've got the option to 'Auto On' or something along those lines, which will make the TV switch on automatically when it detects a signal.
     Weekly top artists:
